Noob question - FL20 spool
whacky
Hello, new to this forum and hoping for some help. I bought a used Weed Eater FL20 (2003 model) and got it running well. I'm just not too sure what line spool is compatible. There is a head on the bottom, and it looks like a line spool just clips in. My local hardware stores have fairly limited selection. Thanks for any help.
And if you a whole head assembly it is NLA and none of aftermarket sources has one for that one with 5/16-24 threads so it is time to look for a used one in that case.
Also there is a small version and a large version with the same threading.
Thank you!
