Non mowing mower
BlazNT
No defineately not a rebadged Honda .
it is made by Stiga - GGP the largest manufacturer of garder care products in the world.
After Electroluxe sold off Husqvarna and Husqvarna went out on a buying spree dozens of smaller European manufacturers merged / took over/ got taken over etc etc ending in this massive Europen conglomerate Global Garden Products.
As it was Husqvqrna just about abandoned Europe concentrating on becoming a dominant player in the North American market so the panic conglomeration was not really necessary.
Well it is a nice looking machine. Built in bagger looks so much nicer than one you slap on the back of a mower.
Raps
Ok, so did as you suggested,still not working, hmm?, ok then out with the pto switch pulled of the connector and gave the orange wire to the clutch 12volts, nice heavy clunk from the clutch operating, so is it the switch? or is no 12v coming back from the pcb to trigger the orange wire?.
I can see the obvious way around the problem but I'm interested now to know where the problem is and how to fix it properly, what's your thoughts lads?, thanks again for all the input and help.
BlazNT
Picture of the back of the switch and I should be able to tell you how to test it. For sure you need to test all wires for 12v with engine running. If you don't have 12v then we need to track that down. If you have 12v then the switch is bad.
