Sounded like it was coming from the starter - Swapped starter with a good one, no change. Since the starter, I have visually checked the engine cooling fan, removed drive belt from mower deck, and attempted to remove PTO clutch due to a broken mounting washer. No problem getting the bolt out, but the clutch is stuck. Still have the noise only when cranking. Any suggestions for the noise or removing the stuck pto clutch?
