No start without jump
Jay aitken
I have an older craftsman only starts with jump box with key so not start issues I assume. Just replaced alternator what ele could it be
7394
Do you have a volt meter ?
Yes test or have battery tested for resting voltage, & Load tested for Amps..
Auto parts stores can do this FREE if you don't have the tester.
But if you do, check voltage, get it started & test voltage again, this should now read higher if Alt is putting out properly.
7394
Welcome Aboard !
