Update: Finished tearing it down today. I found the valve guide on the exhaust to be 3/16" above the casting and the intake 1/4" above the casting. Also the intake pushrod is badly bent. Neither one of the valve guides seem to be loose but maybe that is something that is not readily seen. Additionally, I see that the intake valve guide is sticking down into the combustion chamber 5/16". If I lower the valve guide height on the spring side it is going to make the combustion side 7/8" Isn't that getting close to the top of the piston? I'm concerned about how that pushrod got bent and whether any other damage might have occurred.
John
John
