No Spark to Tecumseh Tiller Engine!
sgkent
i am late to this party. Glad it is running again. :) When in a forum and asking for help I always put my city and state in just in case someone might be a neighbor who knows the device in question. :)
Super job and sticking with it.
dustrtin1975
near Cincinnati Ohio here/ ,, I seem to have the same issue on the same model engine I think this is mine hh60 105106f ser.9088c mine ran pretty good but at full throttle it just sounded like the engine was floating for lack of a better word, so only thing I did was change and set points, from that point on NO SPARK, even had a shop look at it, my question is , where can I locate procedure on how to set the gap for the coil to magneto ?
Scrubcadet10
Moderator
Staff member
Setting the air gap is fairly easy, loosen the coil mounting bolts, get a index card and place in between the coil and flywheel, press the coil against the index card and tighten the 2 screws back up.
