No spark on plug
mahaffeymj
Got two hr215 that am trying to fix up and one of them has good spark at plug. took that coil and plug off and put on other mower, unhooked the kill switch,and gapped the coil the same and am not getting spark. besides flywheel what could be causing that? anyone know if flywheels go bad? thanks for any help/info
Scrubcadet10
Moderator
Staff member
Check the magnetic on the flywheel with a screwdriver or other metal object, it should start to pull about 1 inch away from it.
