I was cutting grass on a ltx 1050 cub cadet and it just stoped no juice any where
Check your battery...maybe it failed internally
checked battery still nothing
Your PTO switch is still on.
Take screw driver and touch between the two large nuts on the solenoid and see if motor turns over.
It won't start...just see if the engine will turn over and not locked up
