No power Cub Cadet 1000 series
Shtiv
Hi everybody,
I have no power, no crank, nothing. Bought a new battery that is correct for this horsepower, I have replaced the solenoid, I checked brake safety and seat switch (appears to be good), replaced nuts and bolts in various places including at the battery, grounds seem to be good, the fuse is good, I just can't seem to find the problem. Maybe the ignition switch? PTO Switch? Any good tuts for checking? Any advice or ideas would be greatly appreciated.
NorthBama
post model number under the seat please
You start by going to cub cadet web page and downloading your service manual and parts book
In one of them will be the wiring schmetic
from there you start tracing the wires and in particular the one connected to the B TERMINAL ON THE KEY SWITCH WHICH HAS THE MAI FUSE ON IT.
