... wont turn over. put a new ign switch assy on but still nothing....
did that Kenny it turns over but wont fire up and run. coils are pulsing from what I can tell. and can smell fuel.
Okay... What are you saying...?
First post you said "Won't turn over put in a new switch assembly but still Nothing" (WHY did you replace the switch?*)
Second says "Still no crank" (so I am Guessing it is in the same condition as it was in the first.)
Third you say.. "it turns over but wont fire up and run" At what point did this take place?? (somewhere it went from won't turn over, to it Turns over but will not fire up & run...
Also Exactly what do you mean by: "coils are pulsing from what I can tell" ???
Not just getting bogged down in terminology But what are you seeing?
Also *(about changing the key switch... I am So against replacing parts Unless You are Positive they are bad... That is Not because of the economics... It is because you are removing a Good part and replacing it with an Unknown 'new' part the new part can be defective or the wrong part but still looks the same, AND it is possible to introduce additional problems anytime anything is removed and replaced). :smile:KennyV
