JonnyBlaze
- May 6, 2017
- 57
- 338
Will do. Thanks!Remove the valve covers and make sure all the push rods in in place and while turning the engine over by hand make sure all the valves open and close the same amount.
Ok. So everything seems to be fine as far as opening and closing on both heads. At no time do the rockers ever get loose when fully open like you would find on a Briggs OHV, so Im assuming valve adjustments?Remove the valve covers and make sure all the push rods in in place and while turning the engine over by hand make sure all the valves open and close the same amount.
How do I find the compression stroke when there's no compression? Im not good at valve adjustment at all.Start with valve adjustments
Usually closed up valve lash is either a mistake setting them or valve guides slipping in the head .
The latter is from overheating
All 4 valves are identical , the valve lift on the cam lobes is identical as are the rockers
So all of them should sit at the same position when their piston is at TDC compression stroke .
If not the guides are the problem.
This can be fixed if they are not too far gone
both valves will be closing or closed as the piston travels upwards.How do I find the compression stroke when there's no compression? Im not good at valve adjustment at all.
Just for additional information. When you are coming up on the compression stroke and both valves are closed. Make sure the spark plugs are removed so you can see the piston or feel it with a pencil or similar, and see when it reaches its highest point and just starts back down. that is the point to adjust both valves. You want it just slightly past TDC.both valves will be closing or closed as the piston travels upwards.
TDC on each piston, right?Just for additional information. When you are coming up on the compression stroke and both valves are closed. Make sure the spark plugs are removed so you can see the piston or feel it with a pencil or similar, and see when it reaches its highest point and just starts back down. that is the point to adjust both valves. You want it just slightly past TDC.
