No brakes
snow blower
Hi My 2007 troybilt super bronco needed a drive belt, after installing that I took it for a ride the breaks worked a couple times and then quit working altogether. I took them apart inspected them all seems fine, I reinstall and the same thing happens breaks at first then nothing???
mechanic mark
Parts list above shows Upper & Lower Transmission Drive Belts. You should replace both belts at the same time with OEM Troy Bilt Parts. Let us know if this helps, thanks, Mark
The question is> Is it pulling through the braking or is it simply not braking at all?
snow blower
Thank you for your reply to my question, my issue was resolved when I replaced the new belt with the correct length drive belt 🙄
