That’s what I was thinking. I’m going to try a few more things in the morning. I’m going to recheck the choke cable adjustment. I’m going to pull the cover off of the mixture screw and see if I can fine tune it. If that fails, I will put a rebuild kit in it and smaller jet. I was hoping there was a Walbro replacement.Might be simpler to rebuild the carburetor and install a leaner jet.
You have a choice of 99, 102, 105, and 109 that leaner than the 112 that supposedly was factory jet.
Or order a new carburetor and leaner jet.
Might be trial and error on which one to use.
