Texasjherrera
- Jun 11, 2017
- 1
- 5
I'm in need of some advice, I've purchased a rebuild kit for my carburetor on my Poulan after it has failed to start the engine. I've come to the conclusion the carburetor was the issue by using an ignition tester I purchased that told me via a sequence of flashes (error) suggesting there was probably an issue with the fuel system. Spark plug and wire was good, changed the oil, new filters, compression is around 90 PSI. So I rebuilt the carb and I've never done it before and I forgot to put the main jet in, I tried turning it over and it wouldn't turn on. After looking at YouTube videos I realized what I had done, I corrected the issue and still won't run, if I spray some starter fluid it starts briefly. Any suggestions?
