oldsman143
- Oct 16, 2012
- 2
- 10
BRIGGS AND STRATTON
INTEK VTWIN 24HP
MODEL 445677
TYPE 0759B1
INTEK VTWIN 24HP
MODEL 445677
TYPE 0759B1
That engine may have a fuel solenoid, if so is that working OK.
Yes that is right.
ANTI-AFTERFIRE SOLENOIDS
Begin troubleshooting the solenoid by checking for battery voltage at the spade connector (with the key switch in the 都tart as well as the 途un position). The next check is to listen at the bowl of the carburetor for a distinct click when the ignition switch is turned to the on position. If a distinct click is not heard, remove the solenoid for further testing. To test the solenoid itself, attach one pole of a 9 volt transistor radio battery to the spade terminal and the other pole to the solenoid case or black ground wire if so equipped. A sharp distinct movement of the plunger should be seen.
A fuel shutoff valve must be all the way open to allow full fuel delivery. Anything less may be
responsible for a restriction in fuel delivery.
