MarkWhiskey
- Jun 17, 2013
- 1
- 2
Hi, thanks for reading this. I'm having a really bad time with my Craftsman 16" chainsaw. I bought it used, and it only started once. I took it apart, and found that after I started it somehow the fuel line broke. I repaired the fuel line and it started and worked very well.
Somehow, three days later, I went to start it and it absolutely will not work. So, I did the following:
Cleaned the carb
Replaced the plug/air filter
Removed the fuel filter
Checked for spark, and got a steady spark by touching the plug to cylinder
Checked the fuel lines and they are all intact
Checked for compression by putting my thumb over the plug hole and pulling the cord
I even shot ether into the cylinder, but it won't even start for a second.
I can't believe it won't work after all these tests. I'm really lost as to what to do at this point. I don't understand how it magically broke after sitting for three days. I also don't see how I can have spark, compression, and fuel, but it still won't pop.
If anyone can give me any advice, I'd really appreciate it. I'm trying to become a better mechanic and I don't want to take the machine in to a service center.
Thanks!
Cleaned the carb
Thanks!
