NGK Spark Plugs
John R
My Kawasaki FX730V calls for NGK BPR4ES plugs, what I'm Finding is the BPR4ES-11, what is the eleven on the end of the number mean, or is this BPR4ES-11 a totally different plug?
That is a pre gapped plug and the 11 is the gap code
Mad Mackie
The gap for -11 is .044". This means that this plug needs to have the gap closed up to I think .030" for use in a FX730.
Special sparkplug gap pliers when used will hold the "J" tang and keep it perpendicular to the center electrode while closing up the gap to the preset opening.
John R
Does NGK have a chart online that shows plug number break down?
Thanks
Mad Mackie
Check out this site
ngk-sparkplugs.com
type in your search, then click on the red icon.
hayboy
You can get a BPR4ES without the #11 preset gap Right?
