G'day,
My Victa 2-stroke (older model, serviced last year), began to shake violently after I cleaned the spark plug and vacuum-valve thing the day before. I think I heared something break off/ snap ooff while it was doing that. I didnt loosen any other stuff except the cover that holds the fuel tank and the bolt-like ring that holds the vacuum valve thing. Especially didnt touch any engine mounts or anything.
I've read that it could be the blades causing this violent shaking, but nothing happened to the blades since the last time I used it (and it was all good), and the first time after the cleaning.
Any ideas on what it could be?Related to this cleaning of mine? I put in a new spark plug, but took it out thinking that might have caused it, but the violent shaking continued. and I couldnt push the throttle forward with the new plug, because that killed the engine.
I'm a bit stuck here, hopefully you could give me some advice.
Cheers.
Cheers.
