Walker3555
- Sep 15, 2012
- 4
Hi
I'm new to riding mowers and lawn tractors and I hope someone can enlighten me on a couple of points. I've just brought a secondhand yardmachine 662, 13.5hp, 38" cut. It works well and starts everytime, but I have 2 issues.
Firstly, the flywheel has lost all its magnets and the charging circuit is smashed. This means I have to periodically charge up the battery, but when I do the mower starts everytime so I can put up with this at present. Is the charging circuit attached to the motor? If I replaced the motor in the future will this rectify the problem? The motor is a tecumseh.
Secondly, the mower cuts well until I hit thicker or tall grass, (6" - 9"). The deck belt, which is brand new, starts to slip and smoke. Is this normal?
Cheers Mark
Cheers Mark
