a_gunslinger
- Jun 11, 2011
- 16
So I inherited a G110 that has been acting up on me very suddenly. I had replaced plug, oil and filter, fuel and air filter and it ran great for a couple weeks. All of a sudden while cutting:
Two other things noticed as possible suspects.
On right front ofengine (from seat perspective) there was alittle splattering of fluid (oil?) from what I think is the "breather/seperator kit" canister according to parts fiche. Canister has a wire mesh inside of it that and the canister sits on the cylinger head I think (?). And tube off top of canister feeds toward air filter assembly. Both the grommet on cyclinder head and the tube to air intake are shot - SEE picture:
Could that compromised systen cause surging?
Also, recently the rubber gasket/extension under the hood that connects the hoods air intake grille into the intake screen came off. It appears to make a solid seal between hood and intkae when hood is closed. Without that I presume not as much airflow into engine cooling? Could surging be from slight overheating? See picture. Picture doesnt show the rubber flange but shows where it it:
Thanks for any and all support and advise. Cant afford to get this serviced right now so Im all on my own.
- Starts surging - revving high, then low, then high, then low. Then it stalls. The surging is very much like the surging you get when you are about to run out of gas, just a bit more intense.
- Wont start unless it sits for a bit, then trouble sgetting it started. Often need choke all on even though hot engine.
- Cut some more and starts surging again, stalls, then has to sit.
