Hi all, new to the forum and have really enjoyed what little I have got to read so far. I cut about 14 acres of grass like a yard. It's not all connected. My mom live on the far side of my property and I try to keep her yard up as much as I can. A couple of ponds that I mow around and my shooting range. Sometimes I think it's way to much grass to mow. I use a Kubota L 3000 DT with a 72" Bush Hog finishing mower and my son does the tight spots on a rear engine Snapper. Mom has a Snapper and a John Deere.
If any body else has a JD L 130 out there I would love to hear your thoughts. Hers only has a little over 200 hrs on it and it's nothing but junk. She bought the snapper because we can't keep the JD running. I'll run down a few things I can think of right off the top of my head.
Engine would run about 20 min. and then die. Wait for 15 or 20 min and it would fire up and run about 5 or 10 and dead again.
Battery would go dead between weekends. Ended up burning entire wiring harness out. Had to rewire the entire mower.
Spindles pulled thru the deck. Had to plate the deck and drill it back out to mount spindles. This mower has been garage kept and adult used since new. This is just some of the major stuff that has happened so far. It lasted till the warranty ran out so all the repairs have been on us. Has anyone else had this trouble?
