- May 6, 2010
- 12,035
Without the supply pump and a return pump it would be a wet sump engine and wouldn't be able to operate at angles past 25 or 30 degrees. In this case the limited factor for the angle of operation is actually the carb float. If it was EFI there basically wouldn't be an angle limit. Could operate at 90 degrees.Sounds like the real deal but why two oil pumps, when one is more than capable of doing the job?![]()
