hrdman2luv
- Aug 23, 2014
- 62
- 345
I bought a 18.5hp OT (42A707-1238-01) MTD (13AS699G088 )the other day, I can spin the motor by hand, but it's hard. Which I think is a good thing. I changed the gears on the starter, because the one that came with it was ground down. (Not a good thing).. Anyways, the newer gear seemed to fit just fine. But, the starter (I'm hoping) is weak. Because it'll turn it over just about 1/2 a turn and then stop. The gears seemed to be sticking up in the flywheel. Since there's no way of adjusting the valves (easily) I thought I'd start with a new starter and battery first. If that doesn't solve the problem, then I'll have to do the valves.. Not looking forward to doing that. 1. Because I've never done it. 2. I don't have any calipers to know how much to grind down.
I'll probably throw in some new battery wires and definitely test the solenoid.
The engine didn't seemed to be abused. There was oil in it. And the plugs looked fairly new. Not brand new. Which is a good thing. That tells me that the problem with it starting, just started.
Also, when I remove the plugs, the engine turns freely using the starter. No knocking, bumping, ticking or grinding..
