The spindles without the pulleys are installed from underneath the deck. With the spindles installed and bolts and nuts tight, the pulleys are installed. There is a hub in the center of the pulleys, remove this from the pulley, two bolts, set the pulley over the spindle. The hub has both a taper and a key slot, line up the key and using the blade bolt and nut you can pull the hub down into place. Then line up the pulley bolt holes to the hub holes and reinstall the pulley bolts. You can utilize the blade bolt spacers on the blade bolt both above and below the spindle to get enough bolt thread to be able to tighten the hub into place on the spindle. Make sure that you place the blade and spacers into their correct position on the blade bolt when you reinstall the blades.
Mad Mackie in CT
I 'm trying to remove the hub, key and pulley from the spindles in order to install new spindles. The problem is that I can't get past the 2 hub bolts. The hub, key and pulley are froze stuck after 12 years. Is there a trick I don't know of ? Advise is gladly welcomed as I a can't replace my spindles until I can remove the old ones.
