Actually Briggs started putting serial numbers on some engines but the age the engine you have it only been model-type-factory code and the date code. It is not really traceable. Removing just it a lot harder to repair the engine later.
You are wise! We agree. I’m 9 out of 10 I can work on the Briggs part. Just helps to have a specific engine type and the date code can matter too.Actually Briggs started putting serial numbers on some engines but the age the engine you have it only been model-type-factory code and the date code. It is not really traceable. Removing just it a lot harder to repair the engine later.
Model, Type, Code numbers are stamped into blower housing.Can anyone help me with a model and type?
There is no plate. At first, I thought it fell off, then I thought it’s stolen, finally I found one for sale and apparently Troy Horse tillers of this era DO NOT have a model/type/date code plate??
I have the horse tiller model but I’m a Briggs guy and would appreciate any assistance?
I’ve worked on probably 400-500 Briggs engines in my life and this is a first for me. Sometimes it’s the wrong recoil cover but never no plate.
Thanks in advance!
Please read the postModel, Type, Code numbers are stamped into blower housing.
That looks like so.eone removed it!Model type code plate is missing. It would of been were that clean rectangle is above the starter.
We agree. Or it was removed by Troy Bilt?That looks like so.eone removed it!
Unless I missed it being posted some place else in this thread what is the serial number of the tiller.We agree. Or it was removed by Troy Bilt?
I’ve found several without that plate of the same vintage.
Anyone help ID the model? Besides 8 HP Briggs Horizontal made sometime from 1998-2004?
The original serial number is intact on the tiller.
