New to me Briggs 8 hp on a Troy Horse Tiller
Did they leave the Briggs decals on them?
Looks OEM except the model/type/date code is missing. I’m very familiar with 3, 5, and 8 HP horizontal Briggs engines.
What hasn’t been touched is the etched serial number on the Horse tiller and the sticker with the model number.
If it was stolen then you need to modify the serial number not a Briggs model/type/date code.
What’s also interesting is this isn’t a one off. I found another with the same model/type/date code missing. It’s the exact same tiller only 2000 miles away.
196427-0149-01- close enough by looking at it and the parts lookup.
I found another on eBay
Yes. Where the model numbers were stamped into the blower housing it would look like somebody took a dremel tool and ground the code portion of the model, type, code.
On Andrew’s the decals are in place. So unlike the Rural King ones, it doesn’t look like Briggs was trying to disassociate themselves from the engine. My guess is that Rural King bought a lot of engines that didn’t pass Briggs final inspection for some reason. Could have been purely cosmetic. So Briggs removed any of their identification so they could be sold at a discount and without warranty. Andrew’s machine was also de-identified, but under a shade tree, and judging by the shiny rectangle framed by dust/dirt, very recently.
Now you know why I don't buy equipment without the numbers. Some are simply stolen equipment with identifying numbers removed. IF someone tries sell me a piece with the numbers removed they can take it to someone else. Honest business or individual have no need to remove these numbers.
The Rural KIng ones were overstock from manufacturers that purchased too many engines for their operation, and the excess was sold under the table at a discount, and the code was removed so the engine couldn't be traced back to the original OEM that purchased them..
Sounds like I need to stop buying things from RK as I don't deal companies like these.
It sorta like a Walmart store I deal with that is cheating their customers on reduced priced items by charging full price at the registers. I have caught onto what they are and do have own way to this thief by register. Most don't ever look at their receipts but I do. They tried to burn me for $20 in the last week as I was buying reduce price produce for my chickens as a treat. The local store has repeatedly told about the problem and they has refused to correct it. Hopefully me contacting corporate via email will get this thief by deception resolved. Sunday will be the tell or not.
Let’s think about this a second. If your going to remove a serial number then the only serial number on the Troy Bilt Horse Tiller is the frame. That information is intact and clear.
There is NO serial number on a Briggs 8 HP Horizontal of this vintage. A model/type/date code only matches to a date built not a VIN.
There are other Briggs engines on Troy Bilt Horse Tillers that do NOT have the plate.
This isn’t like a Honda Rancher with a Frame VIN and and Engine VIN.
I have seen a serial number on many Honda GX engines but not Briggs.
