Brought home my new/old mower a couple weeks ago. It's a 1994ish 721d with a 61" deck and 13xx hours. I cleaned the deck, (did the last guy ever clean the deck? I don't think so) installed floating bushings, greased everything, changed the alternator belt, etc. I didn't time myself cutting my yard (about 1.5 acres) but I know it was plenty fast. Amazing engine. Gobs of torque!
My only concern is what seems like a difference between the left and right hydro action. When I push hard forward on the right side, the sound changes from the normal hydro whine to a hiss or slip (hard to describe - what with the blades and engine going). I don't plan on "flooring" the thing at all - I don't need to mow that fast - just wanted to see what would happen I guess. Should I just not do that and not worry about it? Am I in for it? Do I just need to change the belt or tensioner or adjust something?
Also, what are the little bent metal levers sticking out of each hydro unit? Some kind of relief valve or something? Does it matter how they are positioned?
I hope nothing awful is wrong with this beast. It's total overkill for my lawn, but I love it anyway.
Glad to join the forum!
