Fireman 123
- May 14, 2011
- 42
- 358
I will check the reeds...
and the hi / low knob is intact...when I manually up the rpms it works as it should...if I hold the rpms steady and switch between hi and low the engine drops as it should.
I appreciate all the advice and will track down the help I can get.
I have the online manual...seems to have everything I need. After having the carb apart tonight, the illustrations make a little more sense.
Lawn-Boy Service Manual 1950-88 Complete
Disassembled and cleaned the carb tonight...no improvement.
It will still start but the idle seems like it's too slow to keep it running. If I start it and just touch up the throttle an eighth of an inch, it runs strong and steady.
I tried to check the rpms tonight but couldn't get my automotive meter to work on the 1 cyl. Any way to do this?
If it was my chain saw, I'd adjust the idle up a little and go back to work.
Any other thoughts? How can I get the idle speed higher and what would be the cause of slow / low running speed?
