New Super Recycler sputtering issue.
As the search for the service bulletins on the Toro site requires the serial number, it's possible that only serial numbers covered by the service bulletin will result in positive response.
The OP has a 21386 rather than a 21387 which is the model covered by the service bulletin. But as the problem of sputtering is the same in both models (albeit different size engines), the service bulletin covers replacing the carburetor, and that corrects the problem in the 21387, the 21387 replacement carb could reveal what change is made (relative to the factory-installed carb) and that might be applicable to the 21386 carb, even though there might not be a corresponding bulletin for the 21386.
Thanks for trying.
That is a good observation POM. The "non-Smartstow" Toro model is 21462 and appears to have the same B&S engine: 7.25 ft-lb Gross Torque* Briggs & Stratton® Exi 163cc (engine model is 104M020010F1) From the B&S website, https://shop.briggsandstratton.com/pages/parts-lookup#, the carburetor part number is 594058.
I seem to have the same issue with my 21462 (9 months old). After engine is warm, it will sporadically sputter then immediately resume. I only run ethanol free gas (works fine with other B&S engines), changed spark plug and air filter, but sputter continues. All symptoms points to a carb issue. I have not taken it to a service facility as this is my only mower and I can't "not mow" for a couple/few weeks while it's in the shop. If the fix is replace the carb, wonder if Toro would just ship me one?
20355 model here, same symptoms, this is with a briggs 163cc engine.. dealer is of absolutely no help on this one.. i wonder if carb B&S 594058 would work out?? seems OP has the 190cc engine?? when i google B&S 594058 carb, it looks like theres a vent tube like the stow an go carbs? is this indicative it wont fix the sputtering issue? dealer just wants to grab a service call.. we can look at it.. but theres no fix.. apparently.. so driving 1.5hrs just to empty my pockets doesnt sound like a fun thing to try ;)
serial of the mower itself; 4024 16964
serial on the engine if this is what your asking; 1705 1958 36977
Replacing the 596505 carburetor with part #594058 fixed the sputtering issue on my mower. If you decide to try this, keep in mind that you shouldn't store the mower on its end (Smartstow feature) with gas in it, which isn't something I do anyway. My first priority is to have a mower that runs well. It's too bad this isn't the first priority for the folks at Toro and B&S.
I bought a used super recycler with the 163cc engine, cleaned the carb, cleaned the fuel tank, replaced spark plug and air filter, and I only use ethanol free gas. It still sputters when on bumpy ground, going up a slight grade, and when slightly tilted mowing around trees. When mowing flat smooth parts of my lawn its fine. My model is 21386.
Will carb model number 594058 fixe this issue?
Just installed the 596505 carburetor and I think it fixed my sputtering over bumpy uneven terrain. I have to do a full mow to make sure. Thanks for the help.
