cruzenmike
Hello All.
Just picked up some new Stihl equipment today. After a little bit of research I decided on the following:
- FS 91 R
- BR 450
- MS 271 Farm Boss
A little back story: In 2009 I purchased a Ryobi SS26 string trimmer and a handful of attachments for it including the edger, blower and brush cutter. When I was living in the city, this setup seemed to work very well as I only trimmed around landscaping, had 500 ft of sidewalk edging and only needed to blow grass off of the driveway and sidewalk. I had very few leaves to remove so they were usually sucked up in my HRX bagger. In 2013 I purchased a Poulan PP4218 that I used to dissect a few fallen trees at my Grandparent's house. More recently I would use it to take care of any fallen or unwanted trees on my 3 acre property.
Fast forward to today and my chainsaw has died and my string trimmer is nickle and dime-ing me without it's condition getting back to like new despite what I try. I also have far more fallen leaves on my property now and battle with trying to cut the leaves up with my mower over and over and OVER again. I usually end up with a thick layer of mushy, wet leaf debris at the end of the fall that lines the entire length of my driveway. I also only have a small cement pad for my driveway with most of it being gravel so I have no real need to edge anymore. With more and more trees falling on my properly and my needs around the yard changing, I figured that it was about time to upgrade/replace all of my equipment.
To be honest, I was all over the place when trying to figure out what I wanted to buy. I was adamant that I had all "matching" equipment so I wasn't going to get one brand of chainsaw and one brand of trimmer and so on. Nothing wrong with buying individual tools if each one is the best at whatever it does, but in my case I was willing to accept that I was not buying the best in the class or even the best for the price for the sake of keeping them all the same manufacturer. I had considered going with another "expandable" type system for my string trimmer like the Stihl Kombi, Honda Versattach or Echo PAS, but in the end I new that I would end up with some expensive attachments that I would rarely use. When it came time to seriously shop for the three things that I needed, it was between either Stihl or Husqvarna. This was primarily driven by the fact that they both make excellent chainsaws and both brands were highly recommended by friends and family.
When it came to the chainsaw, I was shopping the MS 271 against the 550 XP II. I know that they are not exactly comparable, but they were the two models of each brand that I was most attracted to. In the end, the Farm Boss, although not as powerful, was still about $200 cheaper. Everything that I read or heard didn't lead me to believe that the Husqvarna was worth the extra $200. As for the backpack blower, I shopped the BR450 against the BT350. For this equipment I only wanted to have something that produced over 600 cfm. What I liked more about the Stihl was the larger, expandable tube. Most of what I was told about blowers from users was that a lot of brands tout high cfm or air velocity but they are often times funneling that air through a small tube. To have a high velocity and cfm through a larger tube will equate to a bigger "wave" of air that will move leaves better. Lastly, the string trimmer was a no-brainer. I was not really impressed with any Husqvarna string trimmers and after using my Step-Dad's FS 70 the last two summers I felt as if my positive experience with his was enough to persuade me towards a Stihl for my trimmer. I decided on the FS 91 R because it was the smallest/lightest unit that I could get that would still accommodate a brushcutter blade. I originally wanted the FS 94 R because of it's "ECOSPEED" throttle which would prove quite valuable with all of my trimming along fences, but in the end it lacked the power and fuel capacity that I would need for all of my trimming around the yard.
All in all I think that I will be quite happy with my selections. One small note, my Wife and I have considered moving sometime in the next year. I really don't know what this will mean for my landscaping equipment needs, but having a decent set of Stihl will certainly put me in a better position to off-load them should I no longer have a need for this type of equipment. While only a small factor in my decision making process, it is always nice to know that something you own will either hold it's value or at least be desirable to others down the road.
- FS 91 R
- BR 450
- MS 271 Farm Boss
