rgpinder65
I just installed a brand new stator in my B&S 15.5 HP Intel Model 28 Engine # 285H77 0122E2 and I'm only pulling 20 volts AC off of it. Is that enough to keep a battery charged when run through a regulator? Seems low compared to what I read. Also, when I put a copper jumper i nbetween the Regulator output (red wire) and the battery, it reads only 12.5VDC which again seems low for a new stator. I would expect at least 13 or higher. The funny thing is that I just replace the voltage regulator a few months ago, so it's basically new. Thoughts?
