jlatenight
- Nov 6, 2012
- 21
Hi, My craftsman mower with a 20hp Intek single barrel is acting up and I need some advice. oil is dripping from underneath the engine, there oil seeping around the base of the engine where it bolts to the chassis. It runs ok if it's idling for the most part, but when I turn the blades on it makes this weird cyclical sound which I attached. It smokes a lot too. I changes the oil/filter, looked at the carb and it looked fine inside. Oil's at the right level. I think it's getting enough fuel. The inline filter has a puddle in the bottom of it, but it's not half-filled by a long shot. Is that ok? I guess I need a main drive shaft seal? Would that account for it running rough and the leaking around the base of the engine? I attached a video but had to zip it. Thanks!
