MowerMike
- Sep 5, 2012
- 85
- 964
Ryobi has joined the dual blade bandwagon that was started by EGO with their Select Cut line of lawn mowers. Ryobi calls theirs Cross Cut, and it's featured on their 21" self-propelled lawn mower with SMART TREK Adaptive Variable Speed. It has dual battery ports, which are switched manually with a key that is reversed to select a different compartment when the battery in one compartment is depleted. Instead of the telescoping handles that have to be fully extended and locked for the mower to operate, there is now a one piece easy fold handle that should eliminate a lot of the problems with bad electrical connections that were causing the mower to either shut down or not start. The price at Home Depot is $599.
RYOBI 40V HP Brushless 21 in. Cordless Battery Walk Behind Multi-Blade Self-Propelled Mower - (2) 6.0 Ah Batteries & Charger RY401150 - The Home Depot
The RYOBI 40-Volt HP 21 in. Multi-Blade Self-Propelled Cordless Lawn Mower delivers the power of gas with the convenience of cordless. The premium HP brushless motor provides more power, longer runtime,
www.homedepot.com
