MowerMike
- Sep 5, 2012
- 85
- 964
Until now this style of edger could only be found in gas or corded electric models. Anyone who's used a cordless electric stick edger knows how fatiguing it is to hold up the handle with the added weight of the battery. Then, there's the constant wear on the blade as it contacts the concrete, since there's no edge protector. This new Ryobi solves both these problems, and in addition has a neat drop down wheel for edging along curbs. I've ordered one, and should have it in a couple of weeks.
Notice how the handle rotates into a vertical position when the drop down wheel is used on a curb, so you don't have to reach over towards the lawn when walking in the street. The handle height is also adjustable, which is a very nice feature for vertically challenged persons such as myself.
RYOBI 40V HP Brushless 9 in. Cordless Edger with 4.0 Ah Battery and Charger RY40760 - The Home Depot
The RYOBI 40V HP Brushless 9 in. Edger is a power packed, versatile, and precise edging machine. Featuring a brushless motor, you achieve maximum power and motor life. With 3 ground mounted wheels, an
www.homedepot.com
