fan45acp
- Feb 24, 2015
- 14
Do you still have the service department phone number and if so, may I have it? [email protected]
mhavanti, Hustler Customer Service 620-327-1345
Thanks fan45acp.
By the way, what is your 45acp of choice?
Mine is a 1911 I won in a competition. It is was built in 1910.
I have had many 1911A1 both military and civilians.
Great pistols.
Thanks for the information, Sir.
Max
I took advantage of a few minutes free time over winter to make a very nice anti-rattle shim out of an ~3" piece of 1/2" copper pipe. When pounded flat it was about exactly the correct width and thickness to fill the cap between the anchor and clutch notch. I bent it into a J to wrap around the top of the anchor finger and slide down past the gap at the clutch notch. I then bent the excess around the bottom of the anchor finger to lock it in place. It leaves about .040 gap for the anchor and clutch to move, but not enough room to build up speed and rattle audibly. I figured copper would be a good choice as a shim between two steel pieces being a much softer and cushioning metal, as well as the ease of forming it.
I took it for the inaugural spin on Saturday and there is no more rattle. Love it.
Can you post any pictures? Thanks!
