New problem with steering on 2554 Husky
Gearjammer
I have replaced a drag link and the steering post on my 2554 Husky as well as rebuilding the offending wheel (left) and now the front wheels have a slight toe out which causes the wheel to gouge the turf in a tight turn as well as turn tighter on one side than the other. Any ideas as to causes and remedies??? Thanks in advance. Gearjammer
mechanic mark
First make sure tire air pressure front & rear are correct per manual. Check parts at rf wheel for being worn out, bushings etc.
