Hey bro,,how many hours do you have on your RSD?I'm in agreement with Kraky. Yes there are a few problems with this mower. I have never seen this one and I suspect it is a factory issue. There is another thread about he bolts holding the drive units in place working loose. Dutifully, I checked mine and mine where not loose and where actually inserted in the correct direction, not upside down. I have to guess the bolt issue was also a factory line issue for some number of units.
Good luck! Overall I am pleased with my mower considering what I paid for it.
Great post brother!!!Guys and gals,
If you have a bolt loosen up, simply remove the bolt or nut, add a drop of blue "Lock-Tite" to the starting threads and you'll not have a problem anytime soon.
Also, consider you're riding a stick horse and each bump the stick horse comes across, it multiplies it through the non-sprung chassis. If I tie your feet to the back of my truck bumper and drag you around my yard which I spent twenty grand on to do the landscaping and sprinklers. I asked for glass smooth and my yard is far from smooth, let alone glass smooth. Now, back to dragging you around the yard. If your head is making contact with my Non-Glass Smooth yard, it will have the shyte slapped out of it no matter the speed I drag you around and over this yard.
How long before you have a brain fart? Will your eyes pop out of the sockets? Do you think there may be a concussion? I can tell you that lawnmowers do have bolt failures, springs breaking and it does NOT make any difference the manufacturer. Read thru all the forums, every brand has had many posts about these problems. It is simply because you're riding it on rough surfaces. Your fault, not the design of the mower. Mowers historically don't have sprung suspensions.
I still maintain, run'em like you stole'em, fix'em if you break'em. And, you are going to break them.
Jersey, I believe you'll get your thousand hours and wouldn't be at all surprised you'll get three thousand with maintenance and a little love.
Everyone have a great weekend.
Oh yeah,,well im glad you speak highly of the RSD!That's funny because the Bobcat was my third choice behind the Hustler and Big Dog. The worst part of those things may be if it runs out of gas in tall grass, it may never be found again with all that green paint. lol
There is only one thing I like about the BobCat so far over the RSD and that is the oil drain hose that is destined to fail after a few years. Other than that and if a person replaces the hose and keeps an eye on the connectors where it meets the block, it shouldn't be an issue.
I don't like the open bearings in the front spindles because sealed bearings are safer in wet areas like Florida and Arkansas. Lack of being able to tension (preload) the spindle bearings when you replace them is a failure built in down the road. Shouldn't be a huge problem overall. I'm just an old engineer and machinist that can't handle a lot of slack that will relate to longevity.
Maybe we can get BobCat to give you and I one each to run the crap out of and do a two year review for them!!!
Thats ok,,let them jump on you for saying it,,Im hoping to get over 1000 hours out of mine then It will just speak for itself and they cant say anything:tongue:Although 2 consistent posters will jump my behind for saying this... I still say the raptor SD is a heck of a value for around $3,800! Is it Flawless ....no.... but overall it's a good value. One of my buddies has a $9,000 Gravely. Shortly after delivery he found out but they had forgotten to put some pretty important bolts in the spindles... at about 200 hours his Governor went out on his engine... now at 350 hours he had a fuse bank meltdown. Poop does happen... even to the expensive machines!
There is a fella that bought a RSD two weeks ago, has 96 hours on it. Already on this third oil change and coming up on his fourth. Probably already done it by now. At this rate, he'll have 875 hours approximately on it before the end of mowing season in Arkansas. If you consider he is charging on an average of 65 dollars per hour as he has the high end neighborhood around the golf courses and doing very well in my opinion. $65 x 875 = $56,875 minus expenses and I'd go out on the limb and figure gasoline, oil changes, blades, belt or two, maybe a pair of rear tires, we're talking about $750 if he were to hire all of this done. He is on the high side of income in mid Arkansas. I've already spoken to him about picking up 4 more of them, hire an operator for each and a secondary man for each mower to run the weed eaters, push mowers and blowers, he can turn his little RSD into a fleet of 5 mowers, pickups, trailors, 10 men, ten weed eaters, 5 blowers. If you consider each employee during the season will cost him approximately $10.50 and hour for about 1212 hours each. That comes down to $12,726 each and that comes to $63,530. So, if he puts in 1212 hours per man for the 5 operators at 10.50 is 63.350, his trim guys at 8.50x1212= $10,302 eac x 5 = $51,150. Insurance, maintenance, parts and fuel. 12,500; 5 RSDs $17,500, 10 Weed Eaters $2,250 $393,900 - 63,530 - 51,150 - 12,500 - 17,500 - 2,250 $246,970 Approximate Net. Jersey, I think he'll do alright if he'll become the business man I think he can become. This is better than most small businesses are doing today. Plus, he can purchase all new equipment each year and now worry about all the wear and tear catching up with him. Excess the old machinery to his secondary (trim) men each year and put the new equipment under the men or women that takes care of and works them as hard as the machines can run. The owner can spend all his time smoozing the customers and keeping them happy, plus doing quality control to make sure he isn't losing the loyal customers.
I've always been the kind of guy that roots for the underdog!
Kind of glad we've got some Open minded guys on the forum here that are going to put the underdog to the test!
No matter what the brand is I always love hearing stories about machines that Perform way above their pay scale. Here's to hoping we can get them cheaper Hustlers up on the pedestal with the Beloved Toro TimeCutters...... Not trying to be a smart alec..... It does sound like those toros Did pretty proper!
The local Lowes (Big Box Store) has stopped selling Toro mowers due to an inordinate amount of service calls and flat out returns. Hussies are also on their chopping list and just this week, the 10 Hustlers usually on hand have grown to over 20 and the orange, green and yellow and red mowers have all shrunk. Move over MTD people Hustler is in the house.
I don't remember lowes ever selling toro around here. Home Depot sells them. I get mine at a dealer for less money.
Lowes sells junkdeere
Cub cadet owns mtd and still makes a very good mower. I feel cub makes the best riding mower. And their zero turns are very good for the money.
Cub makes a great little walker too,,I have a buddy who puts 1000 hours a season on one..great little walk behind,,me...I like to sit now,plus there is nothing moreI don't remember lowes ever selling toro around here. Home Depot sells them. I get mine at a dealer for less money.
