highlander620
- Oct 21, 2011
- 2
- 13
art with the fuel lines check condition then pull the fuel pump off carb 3 or 4 screws may just need a carb overhaul:confused2:
I changed the transaxle fluid. Replaced spark plugs and air filter. It is running good:smile:
Then I went to work on the deck. Replaced the spindle and one of the gauge wheels which was broken. Sharpened and balanced the blades, the best I could for someone who doesn't know what they are doing.
Today the grass was ready to be cut so I put the tractor to work. It seems to be cutting well, with the deck in the highest position. I don't know if I am doing something wrong or if its because my lawn isn't very level but if I lower the deck at all it seems to gage into the ground often. The belt connected the deck to the engine came off once.
The only thing I am concerned about shifting. It has a gear driven transmission with 6 speeds (3 in high,4 in low). When I shift I push the clutch all the way and make sure I am completely stopped. The gears still grind about 50% of the time. It is very difficult to shift without grinding gears.
Is there a clutch adjustment that could fix this problem? Or what else could it be?
On the blades digging into the ground, check them both to make sure one end isn't bent down. I've got mine to dig into the ground hard enough that one end bent down and would grab the earth every time I tried to lower the deck. Taking it off and straightening it in a vice worked for a while but eventually a replacement was needed.
