new member, old problem...again
reddragon
no...the belt has a life span...and when it wears it should be replaced......the new belt shouldnt flop or be too noisy when engaged...and when the blade engagement pulley goes slack..the blade brakes should make contact....tell us how it turns out :thumbsup:
Ifixdit
"My serial # is 0920050005532. Is this a 2006 model?"
Your model is actually a 2005 model. The first 6 digits of the serial number mean Sep 20, 2005 as the date of manufacture. I would check Sears Parts and use your model # to look at a parts list to verify the belt you need. I have seen cases where the sticker info under the hood was different than the parts list online. Good luck!
- Adam
