The exhaust is on the wrong side.
Dang. Isn’t that the exhaust pointing toward the right front?
There is one linked Briggs and Stratton engine that would be a good choice for these Hi Vac machines than the other linked B&S engines and all those linked Honda engines.
Most of the B&S engines and all those Honda engines all dump the exhaust at the Hi Vac chute, That one B&S engine dumps the exhaust at the opposite side. The hot exhaust might be problematic w/ the plastic chute and the nylon bag.
What do you guys think of this?
http://www.smallenginesuppliers.com/shop/html/pages/products/briggs_vertical_shaft_engines4321.html
That engine has the exhaust pointing at the plastic chute / nylon bag side.Dang. Isn’t that the exhaust pointing toward the right front?
Here is the link Bobby
http://www.smallenginewarehouse.com...r=Shaft_fq:"7/8\"Dx3-5/32\"L"&rows=20&start=0
Your block is the bottom one... Your flywheel and head plus your carb will fit on this one........
