got a new mag today for my 10hp briggs&stratton model 204412. used the business card for a gauge and nothing. disconnected the wire on the back thats for the kill switch and still nothing. pull the plug and if i crank on it i can get a small spark sometimes, not often. ive tried other gaps form 6 thousands to 15 thousands, still nothing. this was the problem with it when i got it, no spark and i checked the ohms on the old coil and it read 5 whereas the new one reads 2.5, same as my old 5hp briggs & stratton. so the first thing i need to know is what is the mag gap. also there is a small box behind the kill switch cover that the wire goes to and also the wire from the low oil level goes there too. is that box by any chance for the ignition.
