- Feb 19, 2020
- 118
- 12,662
What you got to realize is that you must know what you are posting about instead of just throwing something out there just to be posting. 99.9% of Briggs engine uses Magneto ignition coils. No external voltage is ever to be applied to them or the internal electronic triggers will be destroyed. Yes there still old points and condenser systems that out there but those are magneto systems on Briggs engines.magneto ignition??? ever heard of a ignition system that's is fired by the ignition control module? power to the coil from ignition and the ignition control module grounds the coil to fire at the proper time
Please do your homework before posting and post correct useful info. And in this case the OP may have an Intek or Vanguard engine and we need the model and type numbers to lookup the engine to see how it is setup. And on top that it might be a EFI model vs carbureted model. We just don't have enough info to work with. Beside if it is a brand new the OP is voiding his warranty by working on it.
