BoylermanCT
When does your warranty expire? I want to know how the deck does when you cut off the bottom bar across the discharge chute!
I'm curious how other manufacturers get the open discharge normally seen on a fabricated deck when their decks are the same thickness as the Raptor's and Hustler can't offer an open discharge on the SD. The SD was the only mower I saw with this design on a fabricated deck. That my be Hustler's hook to get you to go up to the Fastrak for another $2 grand.
