New Husky model 310000 seat problem
Husky42
I just bought a new Husky riding mower that has an adjustable seat that wont stay locked in the position I select. There is a steel spring like handle on the right side of the seat you pull up on and slide the seat forward or back, and it is supposed to lock where you want it. There is little slots on the bottom of the seat that the locking "pins" are supposed to go into when you release the lever beside the seat; like a large spring type lever. The seat starts sliding forward and back, while I am mowing. There is a bolt with a special looking washer on each seat underside, where the seat slides, and there is a nylon slider in the middle that has a bolt hole, but no bolt. I put a bolt in the threaded hole, but this did not help any. I cant find any directions in the manual how to properly adjust the seat. Has anyone had the same problem and know how to fix this??
mechanic mark
Flip your seat over & look at the underside while trying to lock it in place where you want it.
