Bent push rods on the left head (facing the carburetor). Purchased two heads (might as well, 274 hours on engine) and installed. Right head reads 90 psi compression, left head absolutely no compression.
Checked the valve clearances at top dead center. Both valves 0.004". Did a double check by having the exhaust valve completely open while adjusting the intake. Again 0.004". Did the reverse, again 0.004".
Possibly a bad "new" head was sent to me. They were both labeled "Original B&S Parts", and came in B&S boxes.
What gives? Prior to tear down of old heads, the bad cylinder had 60 psi with bent push rods. Now it's zero.
Totally baffled. Any advise appreciated.
Ivan Vegvary
Ivan Vegvary
