I was excitedly waiting for the mower to arrive and decided to check the website as I had received no confirmation about anything. I found that my order had been cancelled! Ordering online is my only choice since they do not carry it locally. The first person I talked to thought they were out of stock when my order was placed but then the 2nd person said it was some kind of issue with the epp. I was half asleep when they returned my call. Anyway I found another 10% off coupon code from slickdeals and placed another order ... and while clicking the submit button is takes me to a page saying access in denied. How frustrating. I've been spoiled as a Amazon customer.
However it did seem to go through and is listed as processing. I'm still not sure they didn't cancel it the first time because they didn't like the 10% off code. So I won't have the extended warranty which is fine I guess. A reviewer on amazon posted a easy fix for the common problem of the mower not starting. You have to remove the cover and bend a bracket IIRC.
I was waiting to mow my front yard until this mower arrived so with the delay it should be quite a test for it. With my corded mower you have to walk slowly for it to cut the grass and I'm hoping I can move a bit faster with the twin blade.
