If you look back to the beginning of this thread I gave you some advice and said that I had tried mulch kits and they just weren't practical and slowed me down too much.
Here are your options.
1) You can try raising up the back of the deck and increasing the rake.  This let's some grass get tossed out the back.  You can try it temporarily by increasing your tire pressure to Max, usually around 20 psi.  If that helps then put them back to normal usually around 12psi and adjust your deck.  I don't think it will make enough difference.
2 and 3 are what I originally recommended.  Cut discharging with high lifts or Gator G5 blades.  If you have some heavy growth areas with winrows after the first cut, finish cutting the whole lawn.  Then come back and mow it again quickly with the deck 1/4 to 1/2 inch or even higher if there's a real lot.  Just letting it sit and dry for a few minutes can make a big difference.  And the last option is having a bagger or catcher to use to pick up heavy windrows, keep grass from going places you don't want it and for cleanups.
There is a real art to trying to mulch commercially.  Some have it figured out and run their business around it.  For most it just isn't practical during heavy growth periods.  Spring is a bad time to attempt it unless you're a master mulcher.  I gave up on it entirely and run Gator 5G high lift mulching blades most of the time.  After cleanups and first mows I'll run regular high lifts through the heavy growth.  Then back to the Gators for summer and fall.
