New Echo Equipment
exotion
Interesting.. I am going to explore that a little I have 3 dead 225 carbs now. I'll try cleaning that screw and see if that works.
Mudface777
Yea man go for it. Let me know how it works.
MowerMike
How do you adjust the jets? Thought they weren't adjustable. I've been through the machine 1000 times never seen an adjustment screw
The high speed needle jet screw is hidden behind a plug that must be removed to gain access. The plug is located just below the primer bulb. You turn the needle jet screw CCW to make the fuel mixture richer.
