new easy RTV sealant
Sounds like something that will leak easier to me.
On mower valve covers? Not much pressure there. Oil pans the same. You can make a paper gasket from a box of corn flakes. Done it before and it held.
Slomo have you ever seen the Kohler Courage Single to leak due poor RTV sealing of the rocker cover? If something is easy to remove usually means it don't stick very well.
All in the prep playa'.
