I have a new ZT1 (17AIEACLA10) Mfg:12/2023.
I have 13 hrs on it and started noticing last week that I get a jarring sound like the deck is loose. Turns out it is the front right caster asssembly. It has about 3/16” of play and jars/bangs while mowing. The left caster has no play. I can see a big washer about 3”dia that separates the caster from the yoke, but is is loose fitting. The bolts on top are tight, I tried to remove with an impact driver but it wouldn’t bulge. Any thoughts? A parts diagram doesn’t show many parts, 2 washers and 2 bearing. Not sure if I need to be concerned. Wouldn’t want to damage the caster or yoke.
